Gimbal
  • Thread starter Thread starter Former member 99658
  • Start date Start date
When the camera does not focus it is often a hardware issue caused by the PTZ cable or the camera unit itself. It seems odd that the issue persists even when you switch another one over. A few things to consider would be making sure that your drone is set to autofocus mode, making sure all the cables are making contact correctly, and checking the cable that runs from the gimbal to the main core although that gets damaged much less often. Another thing to check would be making sure you don't have any firmware incompatibility popups. Feel free to attach some screenshots or pictures and I am happy to check it out for you.
-Kale
Reactions: brett8883
If you are having an issue on the RC / phone side maybe try using a different device or switch between the micro USB port on the side and the USB port on the bottom. Sometimes the app on certain devices can cause issues as well. Make sure your app settings are set to autofocus as well.
-Kale
mini3user
