Gimble.
express500Baz460
Hi. I have just recently purchased a Mavic Pro, and am learning as I go.
I have a small problem, after probably 10 flights, the gimble wheel won't adjust the gimble, it used to now it has just stopped, I had it at work the other day and a couple of mates had a fly of it and it hasn't worked since. Is there a setting there that can get it back working again?
Cheers. Baz.
Make sure the "Gimbal Pitch Speed" is not set to 0 (or a very low number) in the following section of DJI GO:
If that does not fix the problem, then calibrate your remote controller in DJI GO like this.
Klaren
