Yes I agree . It's the normal filter that is on the caméra out of the box.I'm not seeing any problems with these photos. And, you should never use ND filters for still photography. There's no advantage and a big disadvantage in that your shutterspeed will be slower, potentially yielding less sharp images.
As others have mention it is a ‘halo’ and often called Heiligenschein in German. It’s a normal optical phenomenon where the light from the sun is being reflected directly back into the camera lens. You’re most likely to see it where there is moisture on the ground, for example in fields with grassy crops. The drops of moisture (dew etc.) focus the light back in the direction it came from - in this case back towards the sun where your drone is hovering.Bonjour, hello.
Firsts fly with my Mavic 3. I have the normal neutral filter on. It's clean.
I have something like a glare on images on a certain angle but the sun is in my back!
I check the lens and it's ok.
Very strange. I fly another time with the same problem.
Any idea?
Best regards
luc
View attachment 159590View attachment 159592
Very interesting.As others have mention it is a ‘halo’ and often called Heiligenschein in German. It’s a normal optical phenomenon where the light from the sun is being reflected directly back into the camera lens. You’re most likely to see it where there is moisture on the ground, for example in fields with grassy crops. The drops of moisture (dew etc.) focus the light back in the direction it came from - in this case back towards the sun where your drone is hovering.
As others have said there is nothing wrong with your M3 and that this is natural off of wet surfaces. The mistake I made recently when shooting a 21-image panorama was to have the sun in some of the pano images. When using photomerge in Photoshop it makes the sky look horrible since the reflections are in different locations in each image. I may try to clone these reflections out prior to merging and see if that works.Bonjour, hello.
Any idea?
Best regards
luc
You should "rarely" use ND for still photos, not "never".I'm not seeing any problems with these photos. And, you should never use ND filters for still photography. There's no advantage and a big disadvantage in that your shutterspeed will be slower, potentially yielding less sharp images.
this can be easily fixed in photoshop with the clone toolBonjour, hello.
Any idea?
Best regards
luc
Once I realized it was an interesting optical phenomena I liked it .this can be easily fixed in photoshop with the clone tool
Dale
Miami
