Air 3 Gorthgarsdale Beck, Honister Pass, Lake District
AlbionDrones
Manchester, UK
Site
www.youtube.com
The second edited video from a Drone day out with other viewers of the Drone Show Live, captured on Wednesday this week - actually the 4th location of 6 flown, but I'm not editing them in order...
Anyhows, some AIR 3 and AVATA fun, flying low over the beck and under the bridge...
Another awesome video!
One thing I do not understand is how these FPV drones are able to go through 'tunnels' with out going doodle alley.
Do they lose GPS and go to VPS only ?
What about control signal ?
Alex Markov does the same sort of thing.
There's a much bigger arch bridge near me, it must be 20ft x 20ft x 30ft and I would love to send a mini through it and that's stood looking straight through the arch, but I have never had the bottle to try.
Reactions: AlbionDrones
They do have sensors underneath if the satellite signal is blocked, but tbh if you fly in with enough speed you are generally ok...
I have had the AVATA through smaller gaps, but not so long, the only reason I gve this a go was a friend had just done it..
Flying a MINI under a bridge is fun, and a large bridge gap should be fine, I have flown under several with the MINI3 Pro without issue... Take a look at the Falls of Bruar, Blairgowrie and the Invermoriston Falls ideo's on my channel...
Very nice! I have to learn how to do videos one day since I have the gear to do it.
Lots of great tutorials on YT :)
I only started video's when I got the MINI3 Pro, which is just under 2 years ago...
Beautifully flown! The beck (I had to look it up) is really nice! Nice flying through the bridge. I chuckled a bit when you were coming back. I was thinking since you drive opposite of us Americans, you should have flown the left tunnel. (Yes, I have a weird brain) As usual, everything was very smooth, up to and including you removing your goggles and reaching out for the Avata. Great job!
Thank you kindly.. I chose the rh side as it was easier to line up from both sides, so flying up the river I flew the same side... It's in the longer edit here...
Reactions: Prop Wash
jasonmamoa
