Greetings from Jax, Fl.
Wolfebayne
Jacksonville, Fl. USA
Bought my first real drone this past Christmas, (DJI Mini 2 SE) and flew it 3 times and got hooked, when I learned about Costco having the fly more combo of the Mini 3 Pro in May I went and added that as well. I'm new to photography beyond "point and click" but I am impressed with the perspective drones give and anticipate learning as much as I can to enhance my experience and the pictures I take. My wife and I like to get out and about and take trips a couple of times in the RV and figure drone shots will just make those experiences even better. We're located in Jacksonville Fl. USA and unfortunately live in the Red circle of NAS JAX so there's no home flights for practice for me.
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you may have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
Yeah, Jacksonville NAS is pretty Greedy with their Airspace… Anywhere inside that RED Border I put on the map is in the Zero Altitude Quadrant and the FAADroneZone will not grant an authorization for a Recreational Pilot… I live in a Zero quadrant in Virginia, but my Part 107 certification lets me fly here… Get your Part 107 Citification and then you can fly in your own yard…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 2 SE and the Mini 3 Pro, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Noexcuse
