Greetings from Spain
Welcome!
First of all a used "original" dual cam Mavic 3 is still a fully supported aircraft and will remain so just as long as any other model of Mavic 3.
The Mavic 3 (any flavor) is still the flagship consumer drone for DJI and is unsurpassed by any other consumer model.
The Air 3 is an amazing aircraft with very similar abilities as a Mavic 3 but with an arguably slightly lower quality camera.
It all depends on your budget...
Welcome!
Hi 3rdof5, I have the opportunity to get a Mavic 3 fly combo (second hand) at the price of an Air 3 fly combo (new) or a Mavic 3 Classic (new). I understand that the choice would be the original Mavic 3, that is correct?.
New member from Spain.
Since you live in Spain, and you wrote in another posting that you have already obtained various drone certifications, I will not rehash the rules and regs…
Also in your other postings, you have written that you are as yet undecided which drone to get. I will only add that YouTube Videos are worth a thousand words… Be sure to watch the older videos too as they are more into the specifications good and bad… Many of the newer videos only show "WoW, Look What I did…"
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
That would be my choice.
Pro-MBS
