Hi there, thanks so much for the many replies and lots of good ideas. Its a broadcast live production, with the addition of a live drone shot, so unfortunately not much opportunity to do anything too drastic or in post. The LED walls are adjusted for the broadcast cameras, which cope with colours ok. Shoot is only HD SDR, so dynamic range is somewhat limited. I agree underexposing the drone camera might be the way forward, maybe I didn't do enough, but also have the problem that client wants to see surrounding scene AS WELL AS video wall, hence its always going to be a compromise.
SethB
wish I could adjust LED walls for the drone, but cant due to main cameras being the broadcast cameras and drone only as addition.
have looked at WFM, but failed to switch it to RGB during the event to analyse individual channel clipping in more detail, as for other cameras I normally have it in YCrCb for other workflow reasons...
Dave Maine
The histogram you spoke about, is that a feature of the drone, like in an SLR camera, can I just superimpose it onto drone o/p? Where do I switch it on/off? Can I have separate histograms for RGB, or just overall brightness levels?
akdrone
You spoke about still image? Just for my understanding, How is processing of Hasselblad camera of the drone different for still images and video capture?
Mavic 3 pro has multiple cameras doesn't it? Only for different focal lengths or do they differ in image quality??
I understand D-Log gives me the greatest dynamic range, doesn't it? What exactly is the difference between D-Log and D-LogM? Is D-Log comparable to our broadcast standards (Sony S-Log, Arri C-Log, PQ or even HLG) Broadcast cameras transmit 10bit as well, so shouldn't be a problem, would only result in slight banding artefacts if quantisation steps too broad. Does drone use full range (0-1023) or limited range (64-940) as standard? I used standard LUTs from DJI website to convert D-Log or D-LogM to SDR/Rec709, someone also made me a custom LUT but that one didn't work for some reason.
What colour space is DJI drone using? Is D-Log more comparable to Rec709 or rec2020 colour space? Does D-Log give me only more dynamic range in brightness? Or in colour as well? @
BobaFut you spoke about different colour space and possible "DJI color issue"?
The Hasselblad camera is a single chip camera isn't it? With bayer pattern filter? Is it the same principle as in most single chip cameras or is there anything specific with this particular camera?
Just trying to understand the issue more fundamentally so I can get back to the client to explain why the impossible isn't possible.... Wish I could post example screenshots on here, but cant due to confidentiality.
