HD -> Switch To HD Mode - What does it do?
GenCode
Tampa
I am a little confused at what this does
HD > Image Transmission
Switch To HD Mode
Camera will automatically switch to Recording Mode when resolution is 1080p. Only 1080p and 2.7k are supported.
I have 720p selected (Default)
When I try to select 1080p it gives me a message and still goes back to 720p
I did look in the full 1.0 manual but did not see it mentioned (maybe I overlooked it)
Thanks, Ed
If you're recording at a lower resolution (not 4K), you can have the video stream coming to your phone/tablet at a higher resolution (not 720p). If you record high resolution like 4K like most people would, then the video stream is limited to 720p. Otherwise the Mavic processing load is just too much to handle.
Thank you!
cbooth
