Hello from South Florida, just completed first flight!
Skerrabrae
South Florida
Hello from South FL. Successful first flight this afternoon of my first ever drone! Went with the DJI Mini 2 (now named Cricket) and fortunately it is still in my possession without a nick of damage.
Been studying up for Part 107, watching multiple videos, and reading this forum for a couple weeks before I attempted a flight. Found a large open area for the first attempt and used a landing pad for launch/landing. It was actually easier to control this little drone than I anticipated. Held position perfectly, responded well, and the landings went far better than I thought they would.
The only time I panicked was the very first time I hit RTH. Cricket was about 80m out and 30m up. I unknowingly left the RTH height at 100m. So when I hit RTH and I saw her climbing up out of sight, I initially thought she was going rogue and flying off. Tried to remain calm and watched the distance numbers and I quickly realized what was going on.
The only concern I have is VLOS. I always tried to maintain a visual but I found this drone is so tiny, I could not see it against the sky more than 60-70m away. Does not help that I need reading glasses to see my screen while peering over them to scan for Cricket. ?‍♂️
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
I have the Mini v1 and was in your “first ever” spot back in August. Get a strobe for the underside, it really helps keep it in sight even in the daytime. I use the Firehouse Technologies strobe for the Mavic mini.
Also, the automated flight routines like the “Dronie” shot are most prone to hitting obstacles since it’s going to go into its automated flight path and you’re still learning those. Read up on using the sticks to jump out of those profiles if you even think it’s going to bump into trees or something. I did a lot of practice flying on vacant school property during the summer vacation/COVID shutdowns and even on weekends when they opened.
Now I have a Mavic Air 2 as well. Although it’s a bit bigger, I have three strobes on it, top, and both sides. So yes, VLOS is something to take seriously!
Welcome,
Tom
Welcome to Mavic Pilots! I am glad you have the awesome maiden flight and you enjoy the little beast machine.
Welcome to the forum! :)
Welcome from Davie. My first experience with RTH was similar when it went up 300ft to travel 20ft over to the home point. I definitely thought it was flying home to the DJI factory for a second.
FWIW, I have managed to maintain VLOS on my MA2 at an insane distance with binoculars and my DLSR with a 600mm lens.
Welcome from Coral Gables,Florida
Dale
stephy_gl
