Hello from The Washington DC Beltway
DennisFreeman
Kensington, MD
I’ve been flying for more the one year, having purchased a DJI Mini 4 Pro, then an Air 3S. I have to travel to use them, with most of the Washington DC Metro area being off-limits. I’m interested in new locations and am following the politicized drone restrictions. I’m planning a September trip to Oregon, and am eager to fly there!
Hello from the Crossroads of America DennisFreeman.
Nice to meet you. 🤝
Welcome to the Forum. :cool:
Reactions: LoudThunder
there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. Your 3S Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Maryland, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Reactions: MA2 317
aquamusic
