Help with camera
I recently crashed my Mavic pro, found that plastic piece was broke were circuit board and gimble attach. My camera was still working so I reused and ordered broke piece and new gimble. Hooked everything up but not getting and camera transmission. Anybody got ideas, thanks
This is what I do. I take the drone apart, take the gimbal out, and then connect the camera directly up to the gimbal PCB. Dont connect the black cable, only connect the silver cable. Power it up. If you dont get video then, you will probably need a new silver cable.
So the two black on back of board is gimble power, def sounds like I got more problems unless that gimble I replaced was no good
Its either a bad video cable, bad lens, bad gimbal PCB or bad core board.
Hey bud I replaced cable from camera to circuit board, now gimble moves when turning on but not with controller, also the camera faces straight down. I even rebooted. Oh yea the camera now works.
rosolp
