Help With Judder Correction 24p Footage Shot On Mini 3 Pro
phazemonster
Spokane, WA, USA
Hi All,
I’m looking for help with correcting footage shot in 24p and I used ND filters and the 180 degree rule settings with my Mini 3 Pro in D-cinelike. I currently edit my footage on my Mac Pro with Final Cut Pro X and have Capcut as well. I’ve tried creating a new 30fps timeline and increased the speed to 125% and and the optical flow settings within FCP X. I do have Adobe After Effects 2017 as well with the Timewarp effect but there really isn’t any good tutorials on actual direct ways to correct judders from footage shot in 24p, if anyone has any tips for help with correcting judder footage please share
Thank you so much for your help
Hi All,
In addition to the link that Marc posted, also make sure that your monitor is set to 60Hz refresh rate. Newer laptops may be set higher. My was set at 240Hz. Resetting to 60Hz and following the panning rules have almost completely eliminated the judder.
Reactions: MavicAir2Marc
Chicken Curry
