Hi, from Lanham Maryland
Hello from the Crossroads of America Daxflyer.
If you haven't done it yet, take the TRUST test and register the aircraft.
And read the manual a few times too.
Welcome to the Forum. :cool:
Any advice is appreciated!
You have already been given lots of great advice to get you started legally with your new drone.
Since you live in Maryland, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Hi, Daxflier, and welcome to our forum, from Hauptmann in the wide-open-spaces of North Texas!
I'm sure you've noticed how much of your state is no-no for drones, but there's plenty of space left for you to explore. Can't wait for you to share some of your work with us!
Maryland drone pilots is a great group on FB. As you may already know, it can sometimes be difficult to find a good place to fly around the DMV area, a lot of good places are shared on their. I fly Maryland and Virginia mostly. Connect on IG for more info Escape_Velocity_Academy.
From a fellow Marylander, living in Laurel, welcome to the MavicPilots forum! Enjoy safe and happy flying!
Thanks all, unfortunately I live right in the 15 mile DC no fly zone. But I plan on joining a club near me that has a field I can practice on. We are planning a big trip to Arizona and Utah. Any places I can fly there?
Thank you so much for this! I just received the drone and I am reading this and watching some starter video right now!
gimfbsx
