Hi from NRW (Germany)
CarstenM
Germany
My Name is Carsten and I Fly DJMini 2 with Litchi
I have Issues with Virtual Litchi Mission 2.7.1 .
... using the grid function the Copter flys the rhight path and the Gikmbal tilt is ok, but there are not Taken any photos, the camera always films although waypoints say wait and take photo.
Is there anyone having a solution for this ?
Thanx, for reaction,.
I ve moved post to Control Apps - DJI, Litchi, Autopilot, etc...
Hello from the Crossroads of America CarstenM.
Nice to meet you Carsten. 🤝
I don't have Litchi, but other pilots here do use it.
They'll probably pop in and give some advice.
Welcome to the Forum. :cool:
To get a answer ask in this section. Control Apps - DJI, Litchi, Autopilot, etc...
Works quicker. This is Intros 😉
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Welcome from the Hampton Roads area of Virginia, USA. I also fly a Mini 2 but not with Litchi…
I've got lots of advise but first, have you checked YouTube?
Being in Germany be sure you are following all of the laws and rules applicable to you. Here is a DJI Link to Many Sites of interest to all.
Drone Flight Application Strategy Digest, continually updated!
The following YouTube Video by Jeven Dovey is well worth watching and you might even subscribe to his channel…
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
Add wait 3 secs after taking photo
Greetings from Birmingham Alabama, welcome to the forum!
krish
