Hi from sunny Queensland Australia
welcome mate
your going to love the mavic.
are you aware of all of the CASA regs that you need to comply with?
Happy to give advice/lend a hand if needed. Im based just out of Brisbane
I’m a newbie at this so I’m glad to be with you all. I have a Mavic pro
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
Fly On and Fly Safe…
welcome mate
Thanks for the welcome mate.
I didn’t think there were any restrictions apart from airports. And mainly common sense things like near people or into others backyards etc. where do I look up these regs. I’m in Capalaba area. Thanks. For any info. Most appreciated.
Reactions: LoudThunder
Thanks for that info. I’ve downloaded ok2fly app. Now reading rules. You’ve been a great help already. Most appreciated. Cheers mate.
rom10cort
