Hi from the Marshall Islands
The photo you added is not showing. Try editing and removing it and adding it back.
A new member, presently living in the Marshall Islands and just purchased a DJI Mini 4 pro,
Since you live in Marshall Islands, there are specific laws and rules for you to follow, please check to ensure these are current.
Operators must ensure that they follow the following drone laws when flying in Marshall Islands,
*** Do not fly your drone over people or large crowds
*** Respect others privacy when flying your drone
*** Do not fly your drone over airports or in areas where aircraft are operating
*** You must fly during daylight hours and only fly in good weather conditions
*** Do not fly your drone in sensitive areas including government or military facilities. Use of drones or camera drones in
these areas are prohibited
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from the beautiful woods of Maine,USA!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
A new member, presently living in the Marshall Islands and just purchased a DJI Mini 4 pro, a great machine but a lot to learn, My first drone but previously a fixed Wing RC pilot for many years.
A first photo taken on my first flight in BrisbaneView attachment 176141 Australia
Hello, since you live in the Marshall Islands can you tell me if there are any professional drone jobs there? What is daily life there and what you like and dislike about it. Any information would be appreciated
Reactions: LoudThunder
I also have the mini4 pro and Mavic air3 which I love both
Hi, I have been in the Marshalls working for the World Bank for 9 months and this location is great, it is a 3 world location and services are limited but the location and weather are stunning. Most Marshalls are coral atolls with limited land and normally a large lagoon of calm, clear water. I live right on the lagoon water in Majuro, the capital.
There are not many professional drone jobs here at the Moment apart from the UN who use drones for atoll surveys.
The main downsides are intermittent mains power, power was off for 9 Hrs yesterday for maintenance, poor internet and limited fresh vegetables. The brilliant weather with temperatures between 25 and 31C every day and crystal-clear warm sea water, diving and fishing are a plus.
If you are looking to work in the Marshalls and other Pacific islands look at the UN and World Bank options for positions.
I will post some photos in the near future.
djipilot55
