Hi! How do I insert a map into the drone 360 image?
I'm not sure but checkout marzipano.net
It's simple: just draw in the image using photoshop, gimp or something before turning into a sphere with a specialized program. I use to do something similar with my Samsung Gear 360. You'll just have to get used to working with the distortion, but it's not very hard. This is a rough example:
When you turn to a sphere, it should work nice.
Edit: Looking at a second time at the link you provided, I see the map beneath. But it's still the same idea: you can draw the edges of the place where you want to place the map and stich the map to this edges, deforming. It's harder than what I did, but is possible to do... If you stich photos for the panorama, better do the editing before stitching.
Reactions: Fizzbang
KevinC
