Highway Bridge Inspection Strategy
ElCapitanBill
I have been asked to perform a highway bridge inspection under the bridge.
1. If for some reason I lose GPS satellites, what will happen to my drone. Will the vision only system take over and the drone continue to respond to my actions?
2. If for some reason I lose the signal from my controller to the drone while under the bridge, I expect the drone to rise to the RTH height setting. I assume that I could set the RTH height to a value between the water level and the underside of the bridge, after having launched from a point with no obstructions at this height from the bridge.
Your thoughts on these 2 items would be appreciated.
If GPS health drops below a threshold, the flight controller switches into ATTI mode. Depending on ambient light and surrounding surface(s), OPTI mode might take over, but:
Yes it will. Be advised flying in ATTI mode is tricky if you are not used to it.
The Mavic series of aircraft do not have a dedicated ATTI mode switch as the Phantom, Inspire or Matrice series.
It depends what your 'signal lost' settings are. Use 'Hover' instead of RTH.
Be careful when SmartBattery action kicks in! That definitely engages RTH. (and rises the aircraft to the RTH height set prior flight unless you are prepared to cancel it)
Good luck.
artfulaltitude
