Hit a tree branch and mavic freaked out
Johndronebusiness
Good evening,
I have a question, I never flew my mavic through woods but my wife wanted me to get her walked out of this train into open field so yeah I put the tracking mode on her and was controlling the height of the mavic and I accidentally hit a leaf and a tiny branch which threw the mavic out of control and it fell , was close to the ground anyways but then it went full speed upside down spinning and freaking out . I ran to it held it up propellers were spinning so fast and then it just stopped in a few seconds....
Why wouldn’t it just shut off after falling? Is there a setting for that? Luckily I only ended up with a little scratch on top of the battery
And also how do I make sure nothin inside is damaged?
Good evening,
This is where knowing how to do the quick shutdown of the motors is helpfull, by pulling the two sticks down into the corners, a fail safe , unless you disabled it in the settings. The drone itself takes about 3 seconds to realize it landed before it will stop.
Keep in mind that the lights on your drone along with the error messages are all you have to go by , that and the drone reactions itself.
Phantomrain.org
Gear to fly your Drone in the Rain !
Maker of the lunar Landing Pad.
It’s probably fine - there aren’t the ok most any moving parts inside - pit new props on, goto and open field, fly around low to ground and then land. Go look at the flight log files to see I found anything looks out of the ordinary - you will find many posts here on here how to do that
LeoleoLeo
