Horizon issues
drone away
florida
Mavic 3 classic. No crashes. If I take off straight up and hover. Then slowly turn drone on axis the horizon changes from level to about 4 degrees off as it goes around then back to level. Reset compass and I I and recal gimbal. Did manual adjust gimbal and just makes it level in different areas and out in other
If you have not done so recently, a calibration of all anti-collision sensors is recommended, as they do have unpredictable effects on drone flight if left uncalibrated. If this step doesn't solve the issue you've described, such sensor calibrations make for a smoother flight overall, even if they are turned off.
What you are describing is "FPV Mode". From the manual:
Gimbal Operation Modes
Two gimbal operation modes are available. Switch between the different operation modes in DJI Fly.
Follow Mode: The angle between the gimbal’s orientation and aircraft front remains constant at all times.
FPV Mode: The gimbal synchronizes with the movement of the aircraft to provide a first-person flying
experience.
Reactions: Ex Coelis
experience.
It is not on fpv. The drone remains level as the drone turns on axis.
You may be misunderstanding what FPV mode is. When turned on, even though the drone may remain level, the camera is tilted to simulate a turn in a fixed wing aircraft. What you described in your first post is exactly what FPV mode does.
Reactions: Cafguy
I understand what you're saying. Is this horizon tilt constantly in one direction before it corrects itself after a full 360° yaw? (Or is it random).
For example does the horizon drop to the left if it is a left yaw manoeuvre and to the right with a right hand yaw?
Is this happening with video: still shots, or both.
Does the horizon tilt show when you view the stills (or video clip) you captured in flight?
elitewikipublishers
