- Joined
- Oct 3, 2017
- Messages
- 1,092
- Reactions
- 742
Got many of these dark horizontal lines in the water.Mavic 2 pro,shot raw,no editing.At times they were scrolling across the Ipad as I was shooting.Any ideas?![DJI_0366.jpg DJI_0366.jpg](https://mavicpilots.com/data/attachments/64/64816-cf27d7622fdf69caf1b031874c61d265.jpg)
Ahh-that makes sense.Thanks for the info.That's what's known as "prop shadows".
and that’s why you need ND filters, even for photos
Is that because an ND filters allows for lower shutter speed thus blurring the prop shadow?
I'm not sure if an ND filter will help prop shadow because regardless of the shutter speed, the props are still going to be in a position to the sun that may well allow for the effect to be seen. All an ND filter allows for it to change the exposure at a set lighting strength, usually the shutter speed, since aperture is irrelevant at such height a drone can fly and photograph. Only when the shutter is very slow, could this help, so better to use no ND filter and change the angle you are shooting to the sun or the time of day you are doing the shooting.Not so much to blur the prop shadow but to avoid capturing a photo at that very moment the prop shadow is most noticeable
You could also try a high speed fly away because that would allow the props in view, to be lifted higher on that side and possibly out of the camera view, as you take the shot, with the sun at that angle to the camera.
