How can i calibrate my mavic for Lens Distortion Calibration
abbas
Pak
Hello there i am developing android app using dji's msdk and my baseline use-case is to stream video to computer.
well for now what issue i am facing is that i need to get encoded raw video frames from drone but to get it LensDistortionCalibration should be done i have calibrated drone 2 time but still same results.
Here it says that it isLensDistortionCalibrationNeeded should return false to get raw frames so can anyone help me on how i can calibrate lens distortion ?
Reactions: RCFlyer
Do you need This: ??
Parameter​
value​
SD​
Unit​
f​
10.26mm​
Exif mm​
fx​
4479.94​
2.26513​
f in px​
fy​
4374.51​
2.15679​
cx​
2727.48​
0.813274​
principal point px​
cy​
1811.92​
0.719281​
skew​
-1.91657​
0.0843506​
k1​
-0.0196948​
0.00126486​
Radial distortion​
k2​
0.00652119​
0.010933​
k3​
0.0909295​
0.0368218​
p1​
0.000237354​
2.27565e-005​
Tangential distortion​
p2
0.00108494​
3.73953e-005​
Reactions: abbas
Thanks for reply but i need was to know if there is any calibration routine for drone so that i can call it in my app and fix the problem programmatically.
One solution that i have found is that dji provides external anti-distortion library for same scanerio now i am exploring it.
Reactions: Cafguy
Would that be DJI TERRA by any chance? This does automatically recognise specific DJI camera profiles and offers an 'undistortion' switch, so somewhere in a subfolder there will be dat files containing factory accurate distortion correction parameters.... Hmmmm..... definitely worth a look.
No i am using Dji's android Sdk
jimi79
