How do I verify I got the dji mini 3 extended plus battery and not the standard battery?
It doesn't have 249g stamped on the part that sticks out of the drone. That's the easiest way.
Or, squint at the tiny writing on the label and find the capacity. The standard battery is 2xxx mAh, the extended 3xxx mAh. Don't remember the xxx digits, doesn't matter.
Reactions: Skydreamer
Depends on where you got it from and if you bought OEM or aftermarket? For example, you saw a really cheap aftermarket battery on AliEx and when it finally arrived, you could only squeeze out a few more minutes and you are concerned they simply sold you a plain unmarked standard battery.....
Reactions: chong67
Is this the real DJI battery?
My Plus OEM from AliEx is coming this week. I shall check it out.
Confirm no marking on plus my us bought one has none
I order June 29, arrive in Atlanta July 25. You can track it all the way.
It weight almost the same as the original Plus. The battery stats show up on the display.
Love it so far. The hidden secret.
wang
