How does a drone rotate about a vertical axis while in a stationary hover?
Mavic Air 2
Kent, UK
I am intrigued how my (Mavic Air 2) drone can rotate about a vertical axis while in a stationary hover in still air.
It is obvious how a drone moves in any direction in a straight line - apply forward stick and it tips down at the front to develop a forward thrust, and the stability modules provide the information to maintain stable flight and prevent the drone from climbing or losing altitude while flying in the desired direction.
However, I was hovering my drone indoors after a firmware update to check all was ok and was watching it as I rotated it to the left and to the right on its vertical axis. There is a change to the sound of the motors while it turns, but other than that there is no change in attitude. The drone remains horizontal and stationary. How is that? There does not seem to be any action or reaction to Newtonian forces!
An explanation would be very welcome - Thanks
Reactions: okw and Prop Wash
It uses conservation of angular momentum, although it may be easier to visualize in terms of net torque on the airframe.
It has 2 motors spinning clockwise and 2 motors spinning counter-clockwise which, if all spinning at the same speed, provide a equal transfer of CW and CCW angular momentum to the surrounding air. But if you speed up the CW motors while simultaneously slowing down the CCW motors (so as to maintain total lift), then more CW than CCW angular momentum is being transferred to the air, which results in a net CCW reaction torque on the aircraft, and so the aircraft turns CCW.
Don't you mean a Horizontal axis?
Vertical is up and down.
X = Vertical Y = Horizontal
Remember X to the left Y to to the sky
Reactions: Prop Wash
Nope. If you rotate around a vertical axis you are level horizontally.
X - longitudinal
Y - lateral
Z - vertical
Rotation about X is roll
Rotation about Y is pitch
Rotation about Z is yaw
Contrary to what I posted above (confusing myself now) I always thought X was left to right ( horizontal) and Y was up and down (vertical)
Brain hurts now. I stand corrected. Back to school for me.
There is no standard mathematical convention for 3-D cartesian axes, other than the right-hand rule. In aerospace applications, however, there is a convention, which is right handed with x forwards, y right, and z down:
So in conclusion it's neither X nor Y axis, but Z axis in this case as far as aeronautical terms go?
From what I understand your asking, two opposite motors (ccw or cw), speed up and the others slow down. This imbalances the drone, in a good way, and causes it to rotate. Hope this helps.
The following is from a yaw-test, indoors, with a Mavic 2 Zoom. I tried the same thing with a Mavic Mini but the motor speeds are so much higher that they and the automated motorspeed adjustments conceal the variations of motorspeed due to commanded yaw.
Reactions: SkyPath Productions
I have a related question; I'm on my third Mavic 2 Pro (each replaced with a new one under warranty) and they all experience this undesirable rotation about the vertical axis when I hover for long periods shooting hyperlapses. Not all flights have this problem but many do. I've always thought the issue was wind but it happens even on what seem to be calm days (but who knows what's at altitude).
I just wish there was a way to counter it or even better, have the Mavic MAINTAIN its orientation. It does a great job of maintain POSITION but the rotation (yaw) is ruining many of my hyperlapses.
Oh and almost all of the time, the rotation is in the clockwise direction (more than 9 out of 10 occurrences).
Impossible to say what is causing that without a DAT file for one of those flights.
Reactions: DoomMeister
gonzoales
