How many Amps?
No, it's less than that. Flying sport mode with full acceleration is somewhere above 7 but less than 10 amps. Flying in Cinesmooth is below 5.4 Amps and p-mode is between 5.4 and 7 amps. Full braking takes 7-8.5 Amps.
Here is a screenshot from airdata with Flight specific Full range Amp map.
That is a a very broad range of amperage, especially on a multi-cell Lipo. In high winds, that is a problem.
Straight from the specs for 2400 mah to give 30mins that’s 4.8A average. Peak load will likely be close to twice that.
Not necessarily. Why? The wind problem you are likely to have is inability to fly home against it. The FC will limit propulsion output well before you find the C rating of the cells as a limitation.
it is a very narrow range to be exact. Idk what youre used to, but I also fly fpv, and like 10 amps in hover and 120 amps full send is pretty normal. amp draw varies all the time. a huge wind peak and the motors pump amperage cause they need torque to counter act... not sure what youre saying cause 5 to 10 amps is a VERY narrow range..
The Mavic Mini uses Li-ion batteries, not Lipo's. One of the reasons I love it so much, same tech as my camera equipment, can do a six day backpack hike with it, all batteries fully charged, no 'self' discharging along the way.
rittercu
