How Many and What GNSS Receivers?
Chapperz
London
Hi
When creating GCPs, how many receivers do I need? Can I use one and create the GCPs or do I need two - a base station and rover?
Thanks in advance
Regards
it's based on acreage, good rule of thumb is 5 per 10 acres, make sure you have a full line of capture/flight path past the GCP. And you can either use one reciever if your using ntrip to mark the gcp, or better to use a base reciever on ntrip, and a rover to mark the gcps communicating to the base station
THANKS FOR THE REPLY
RobertCNewman
