How pan left-right smoothly (a video)
swb_mct
The gimbal stability is amazing . . the camera tilt control is pretty smooth, but I can't perform a smooth pan with the camera. The Mavic left-right turning controls is sensitive and it not easy to sustain a slow rotation.
Other than just stick practice and setting your EXP slower I like to and works very well if working in close use Tripod mod . Can speed it up in post and just works well for me .
Reactions: swb_mct
Thanks everyone for so much information . . I will dig in and find the settings you refer to in your replies.
You could also use tripod mode.
In Tripod Mode, the maximum flight speed is limited to 5.6 miles per hour and the braking distance is reduced to 6.6 feet. Responsiveness to stick movements is also reduced for smoother more controlled movements.
Read the manual and use Tripod Mode carefully.
Reactions: swb_mct
Gavthistle
