How to change default storage from hd to sd?
Kierchaps
So as I understand the air records to hd first then sd. Problem with that is you have to plug in with the usb c with the air on. Purring away. Does anyone know how to change the default to the Micro sd?
You can change it under Camera Settings in the DJI Go 4 app, by choosing the far right tab in Camera Settings (looks like a cog) and then there is a drop down to write to SD card first rather than internal storage.
Reactions: Phantom1950
If you change this setting to SD will that setting stay there or do you need to adjust it each time you setup to fly ??
stephy_gl
