- Joined
- Dec 24, 2016
- Messages
- 5
- Reactions
- 0
- Age
- 39
Well what's stopping you? Remote limit? Or video transmission problem?
Take a picture how you fly with your radios antennaya i already set max distance in the app 8000m but when i fly and reach around 1.2 km it show weak signal alert . somebody said 2.4 ghz to 5.8 ghz need to change is that right?
The long flat end of the antennas should be pointing directly at the Mavic or in its general direction. In the EU we are limited to half the transmission power, this is set by GPS position and have not seen a hack for it (not looked very hard though) There will be other factors to consider, what is between you and the Mavic, any microwave transmissions crossing your flight path, highly populated WiFi area etc. In the settings of the app under User info, you should be able to set your location to US. After that you will be able to change the control to custom and have a few more channels under there.
