Thanks, Ok, but this is not good to put on google translator, for example, and that is what I need.I just use the snipping tool of Windows to crop out the part in image form.
DJI blocked the document?Can anyone tell me how I can copy / paste, since DJI blocked it in the document?
On my PC running Windows 10, the text can be selected, may be copied, but not pasted.The manual at this link can be copied and pasted:
SO after reading your post, I gave it a whirl....Cut and paste, no problem on my Win10 machine. ????? As a matter of fact I still have this in my copy queue of page 6:On my PC running Windows 10, the text can be selected, may be copied, but not pasted.
Thanks.Use the unlock pdf function in this tool : iLovePDF | Online PDF tools for PDF lovers
Are you sure about that?
Portuguese: https://dl.djicdn.com/downloads/Mavic_Air_2/multi/Mavic_Air_2_User_Manual_v1.0_pt.pdf
English: https://dl.djicdn.com/downloads/Mavic_Air_2/Mavic_Air_2_User_Manual_v1.2_en1.pdf
I hate to tell you, but so is the English version.Have you noticed that the Portuguese version is out of date?
You can copy and paste from the English and the Portuguese versions.Yes i,m sure, but in English version ... ok ?
Both are the latest version produced by DJI..Have you noticed that the Portuguese version is out of date?,
That was the first thing I tried. On other occasions, it worked, not here. But I solved the situation with the suggestion of the boblui member.If you have the Chrome browser, just open open the user manual in Chrome from the Downloads page. Click on the printer icon and select "Save as PDF" for the "Destination", open the resultant file in Adobe Acrobat. You should now be able to copy any text in the document. I have found this works for any protected PDF document.
Why the problem at all?That was the first thing I tried. On other occasions, it worked, not here. But I solved the situation with the suggestion of the boblui member.
Thanks, problem solved.Use the unlock pdf function in this tool : iLovePDF | Online PDF tools for PDF lovers
