- Joined
- Oct 12, 2016
- Messages
- 30,349
- Reactions
- 34,287
- Location
- Harrisburg, PA (US)
- Site
- mavichelp.com
28 images with the 70mm lens. I think it was 4 rows of 7 columns of shots. If I had used the wide angle it would have only needed a few shots. Was seeing how it handled a high resolution file like an old gigapan panorama.28 image and it wasn’t even a 360 pano?
How many shots does it take if you do a 360 or 180 pano?
Yes, different folders and the files were also named sequentially in the series PANO_001, PANO_002...etc.Thanks for those details.
It did save the individual images in their own folder, so that you don't have to figure out which ones in the series?
Especially since the number of shots will be variable depending on the borders you selected.
The basically duplicated file names actually wasn't much of a problem on import. Just bring them all in. In Library thumbnail view search on text "PANO". Then just select everything, Photo->Stacking->Auto Stack by Capture time and set the capture time to around 6 seconds and it will figure out the proper photos that go with each panoramic and make a stack for each pano group of photos.Lightroom doesn't handle it well at all.
Maybe best to rename the folder or the resulting Pano.dng to something more descriptive than PANO_001-Pano.dmg, which is what LR would do if you merged the files as they were named by the drone on the memory card and you copied them over.
It's not supposed to be a pano just a super high resolution standard 24mm view but using the 70mm lens. I'm using 3 x 3 but in reality what the drone provides you comparing 24mm to 70mm isn't exactly 3x I think it's more 2.5x or something like that. You can still take awesome panoramas but if you want to capture a 24mm (or thereabouts view) and have total resolution similar or better than some high end DSLR's then this is the way to do it. Will dynamic range be as good? Probably not but you now have the ability with the Air3s to automatically capture super high resolution effective 24mm stills and blow those up real big with great quality. It's like the missing link sorted between the quality you got from a DSLR and a drone camera. I'm really stoked for this development and makes the Air3s unique apart from the Mavic Zoom I believe and one of the higher end drones.9 shots at 3 x 3 rows and columns?
That doesn't seem like a panorama so much as a super shot.
Needs to be wider aspect ratio.
So true extremely flexible and the 70mm gives you that unique super shot ability which we have never had as an auto capture function so very exciting!It sounds like it's relatively easy to select the area you want to cover with multiple shots and stitch together.
So I guess you can make a wide aspect ratio pano or a more square or 4:3 super shot.
Air 3S has the same free form panorama feature as the Mavic 4 Pro. It's not available on any other drones.Hi,
This is from my 70mm cam on my Mavic 3 pro shot yesterday, it is natively about 23,000 square and I do this manually and it can be a chore that takes up an entire flight to make sure I got it in the can. Can one do this free form using "Free Panorama"? I see it is a feature of the Mavic 4 Pro, not sure if a firmware update will do it on my Mavic 3 Pro as I usually stop updating after a certain point.
What is the low down on this, can we do these free form?
But to confirm, it is totally free form?Air 3S has the same free form panorama feature as the Mavic 4 Pro. It's not available on any other drones.
