F Fozgate67 New Member Joined Apr 16, 2018 Messages 2 Reactions 0 Age 57 May 1, 2018 #1 Remote control help
msinger DJI Drone Expert Approved Vendor Premium Pilot Joined Oct 12, 2016 Messages 29,130 Reactions 32,407 Location Harrisburg, PA (US) Site mavichelp.com May 1, 2018 #2 Neither is better. I like to use the bottom USB port since it's easier to find USB to Lightning alternative cables. Reactions: FL1H1
Cimriver Well-Known Member Joined Jan 22, 2017 Messages 175 Reactions 64 Location Montrose, Colorado May 1, 2018 #3 I use the bottom usb to reduce wear and tear on the side usb which you have to use to charge. Reactions: FL1H1 and Mako79
Mako79 Well-Known Member Joined Oct 13, 2016 Messages 536 Reactions 293 Age 45 Location Sydney May 1, 2018 #4 Bottom Reactions: FL1H1
Mymgb Well-Known Member Joined Nov 3, 2017 Messages 169 Reactions 71 Age 78 May 1, 2018 #5 Me too. Back USB slot Reactions: FL1H1
D dalawre2 Member Joined Jan 3, 2018 Messages 17 Reactions 11 Age 54 May 1, 2018 #6 Bottom so you don't drain the controller battery. Reactions: FL1H1
BIGLUG24 Well-Known Member Joined Sep 11, 2017 Messages 172 Reactions 36 Age 69 May 1, 2018 #7 bottom
Kenny.j Member Joined Apr 11, 2018 Messages 20 Reactions 6 Age 47 Location West Lothian, Scotland May 2, 2018 #8 Never knew you could use the bottom usb instead of the side one. I'll have to give it a try. Reactions: FL1H1
Mako79 Well-Known Member Joined Oct 13, 2016 Messages 536 Reactions 293 Age 45 Location Sydney May 2, 2018 #9 Kenny.j said: Never knew you could use the bottom usb instead of the side one. I'll have to give it a try. Click to expand... Just don't try both.. she won't like it =) Make sure you remove the side port USB cable, otherwise the bottom port won't work. Reactions: htafc65
locoman Well-Known Member Joined Aug 26, 2017 Messages 801 Reactions 383 Location Western, WI USA May 3, 2018 #11 dalawre2 said: Bottom so you don't drain the controller battery. Click to expand... Bottom and iOS devices does not drawing power from the RC. So don't worry about draining the controller battery. Also, the side port socket is a little touchy, and I don't think DJI's side port cable is long enough for a Mini4. My setup Reactions: htafc65 and JMF
