I want my Mavic to rotate smoother (ease-in, ease-out) for more cinematic results
dirktwa
I tried Cinematic mode, but rotations are still not smooth. Can I change some settings to achieve what I want? Any help would be very appreciated.
What exactly do you mean when you say it's NOT smooth? From an aircraft rotation standpoint, or from a video standpoint? Also, consider the rule of shutter speed to FPS ratio of 2:1 for max smoothness.
I mean that when I rotate my aircraft using the left stick, the controls are too sensitive and they don't make the rotation ease in and out. I want it too ease. So when I push control left, it should ease in. When the stick centers again, it should not immediately stop rotating, it should slowly stop rotating (ease).
Reactions: techdude
You could try changing the curve of the yaw axis in the settings. Have it start out flatter and then increase quickly.Turn the EXP of Rudder L/R down to something like 0.15. You'll have to still be fine on the controls but it should help. There's no specific ease in/out mode.
Hi
Tried your settings....worked just fine.
RobertCNewman
