IMU
Baldric99
How long should it take to calibrate IMU,
Mine gets to 2 out if 6 then just sits, for ages.
is that normal.
TIA.
Aggghi. You got me there, I have a Mavic Po but I also have a Spark and it’s that the taking the time. Its been sitting doing nothing of late, so I thought I would check it over and give it a fly.
Was it flying ok the last time you had it out?
Have you tried flying it before this issue?
Yes. It was fine. Must have been a year ago, I normally use my Mavic Pro.
i was only trying it out in my back garden, only up to 8 ft. Just to make sure it still works, I tried to do an update but there is none. So I thought I would give it the once over.
If it was ok the last time it flew, should be fine this round.
I tend to do some research before hitting any update button just to be on the safe side. Some updates are better off left alone.
Thanks.
I was only concerned that the IMU never completed its setup. Does that mean it’s not safe to fly.
The spark is one of the few DJI products I don’t have, so I can’t say what may be in the system to indicate to you if there is an issue that may need to be remedied. If you can fly it safely, probably good. If you’re not sure, find a big open area with no one around and give it a try. Post results later please.
Reactions: Baldric99
KiKiHUN
