I'd like to get some input on this video:
What should I adjust to get better video quality? (This is Mavic Air footage...)
I'm using an ND32 filter. Should I ditch the filter and just use the stock lens and auto settings, since I don't know what I'm doing? I thought the filter would really help with a bright environment like this with light reflecting off the snow.
Being a beginner myself, and after watching tons of youtube videos, this is what I have found;
The ND filters (described as being sunglasses for your lens), helps with the brightness, so you can bring your shutter speed down.
This should be about double your frame rate. So if your shooting 1080p at 30fps, your shutter speed should be 1/60. For 24 or 25fps it should be about 1/50.
If you are shooting towards the sun, like in some of your shots in the video, you could invest in ND filters that also come with a polariser or /PL (E.g. ND32/PL), this should reduce the sun glare.
I got the PGYTECH ones from amazon, about £58. A 4 Pack, ND4/PL, ND8/PL, ND16/PL and ND32/PL.
Now as for camera setting....
If you are not familiar with post editing software, do not listen to every single youtube video that says "Shoot in D-Cinelike", I've not liked 99% of my video I have shot like that.
This weekend, I shot in "Normal" colour mode, and the video came out great.
I recommend using manual settings, as auto settings can change your settings as it is recording, and your recording may not be consistent.
Here are my camera settings I used this weekend.
ISO 100.
1/60 30fps 2.7k
Style - None
Colour - Normal
White Balance - Sunny.
Most youtubers recommend keeping the ISO on 100 or as close as you can get it, as the higher the number the noisier the image.
Style is up to you, depending on what you are filming, there are a couple of presets, but you'll probably be ok with None.
White Balance is best to set on the kind of day it is, e.g. like your video it was sunny. But this can be changed to cloudy, none, custom, etc.
If you want to check out some of my videos, you should be able to find me here;
Drone Munky
Or search 'Drone Munky' on YouTube.
Hope this helps, and you can get video you love.
