Ok so that first method is tap to fly free I believe .. I wasn't sure if it would maintain a straight camera path but just saw a video that said it was ... pretty amazing that it can work given that the camera cannot rotate independently of the yaw! Now I need to look at the spotlight alternative you mentioned. Thanks for the help!
Is there a mode in which I can fly in a straight line past an object while the camera remains locked on to the object? ...
Once you have the target selected you can then pull in or back off and change height. The left/right movement will then run in a straight line keeping the camera pointed at the target.I will try it.
Spotlight an object, then fly past it?
