iPad image capture
Are you wanting to do a screen recording.
Well yes, I see YouTube videos with the drone video and an overlay of the controller data While it flys.
I don’t mind if I have to meld it together in post production.
Well my iPad is up to date and all I do is pull down the top right of my screen and there’s the button to do so. Just remember when you are done to pull it back down and cut it off. Saves to your photos in your
device. There are other ways but have never used them so can’t advise you on those.
Is that with the Fly app running?
Pull down on the top right corner of your screen. Hit that circle and
it counts down from 3. Yes I will do it with any of the apps running.
I start it whenever I want. Then cut out what I don’t want.
Sorry but when I put my finger on the top right and pull down it get some web screen.
I have an up to date iPad Air, can you post or describe the image of what you are putting your finger on if it is some sort of icon?
We must have past. I just did.
OK I got the image you sent and I managed to get that displayed, which button do I press?
One under the speaker.
Once you press it push that screen back up and all will be recorded.
Thanks very much, will try it out when the rain stops.
Practice a little with it doing whatever. I use it a lot as I fly over water
the most and have a record at least if I sink it. All goes good I just delete it later.
Reactions: sarniac
Media-DD
