iPhone 13 and MM1
beatleboymatt
Ohio, USA
A friend of mine wants to get a MM1 and he has an iPhone 13. Will it be compatible to work with that drone/phone combination?
Thought you guys might know.
Hi I have a Mavic Mini 1 & I have a iphone 13 pro max & I find there is very little room to get data cable into the phone, because of the controller arms.
Anyone else come across this, if so what is the solution?
Reactions: rickmurray1989
There are several 3rd party controller to phone cables available on Amazon that are longer and can resolve your issue. I also use an iPhone 13 Pro Max, but I haven't had any issue with the original connector cables on any of my drone's controllers.
The only problem I have with the iPhone 13 Pro Max is the room in the arms. I have to remove the phone out of the case and even then it is a very tight fit. The cable is nearly impossible to fit in there, it is possible.
d-dot27
