Is it possible to replay a mission and repeat from the original flight
wallopadonkey
north wales
I’m using a Mavic zoom, I have litchi, and go4, I gave a route I wish to fly slowly with the drone then gave it fly the same route through the trees but a little faster and smoother whilst I control the zoom, I’m happy setting missions on litchi but the maps are not always updated, any idea, I’ve been told to try dji pilot but u can’t see where it will copy a flight or duplicate it, I understand once I’ve set a waypoint mission I can replay it but I want it to learn the mission from the flight, not the other way round.
picture for attention.
cheers
You can set waypoints and POI's manually with both GO4 and Litchi using the c1 / c2 buttons on the back of the handset (depending on how you have set the controller up). So the idea is that you fly to the start point and set that up including the camera angle. Fly to the next and repeat. Keep repeating unit the last waypoint. Then save the flight path. It's the same process for both apps.
Once it's been saved you can make all the adjustments you need to on the app. Got to say it's a lot easier with Litchi though. Personal choice. Other apps are available etc etc.
Reactions: RonW
Viktor1991
