Is the Air 2 and Air 2S Controller the same?
RealSting
United Kingdom
Hello, just about to order this from Amazon..
LICHIFIT Adjustable Remote Control Flat Stand Tablet Holder for DJI Mavic Air 2 Remote Control Quick Release Accessories​
Q. Will this fit the Air2S controller?
Thank you.
There are two versions of the controller: The DJI RC-N1, and the DJI RC-231. They are similar in size and weight, but internally a little different, but the holder should fit on both of them.
Reactions: RealSting
There are not two versions of the controller. The R1-N1 is the name DJI uses and RC-231 is the part number. You'll see a box or marketing material that says R1-N1 and then see RC-231 on the actual controller itself. They are the same controller. They have made changes to it over time (color of lights and wording) but they did not change model or part numbers for that.
Correct!
Which was dumb. Exceedingly so for a company the size and scope of DJI.
The cost of part numbers, even accounting for the entire administrative impact on databases, support docs, etc., is miniscule compared to the support nightmare that will result if there ever is some failure that is distinct between the different versions.
Like, the white LEDs had some defect the green ones don't.
johnreinamarille
