Is There a Record Time Setting?
Ray&Paula
Clio, MI
I noticed today while recording in 4K 30fps with my MA that it would stop and restart recording just under five minutes. I flew for about eighteen minutes in which I ended up with four separate clips. The first three clips were just under five minutes with the last one being little over three minutes. Is there a record time setting somewhere that I'm missing? I'd like to add, it doesn't appear that there are any dropped frames between the stop/restart clips. Also, my micro SDXC card is a SanDisk Extreme Plus 64GB and always re-format with the MA .
Unfortunately max file size is 4GB, video will be split at this point. It is not a file system limitation (ExFAT can handle greater than 4GB) but the actual video container which is a 32bit structure.
Thank you..... that explains it. My card is formatted in ExFAT. I took a look at the file size of those clips which shows 3.77GB each. Those clips are 4:51 minutes each. I've had the MA since May in which I've only flown it under this limit until lately. Thanks again.....appreciate it. Ray :)
ExFAT or Fat32 makes no difference, it is the video file container being 32bit that is the limitation.
LV_NV_limitless
