Just got the Tripltek 8. Enclosed is a Matte screen cover. Should this be used or just go with the screen as is?
Mine came with it on and I left it on for glare.Just got the Tripltek 8. Enclosed is a Matte screen cover. Should this be used or just go with the screen as is?
I really like the idea of having a screen protector, but I don’t like the matte one. Does anyone know of tablet screen protector that would be a good fit for both the 7” and 8” Tripltek?
MA2 317" data-source="post: 1367757" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Ordered, thanks!
The matte screen protector cuts down on glare,so I leave it on.The screen cover from them is bunk. Instant garbage heap for me. The display is tough enough you won't likely have problems before it is time for a new tablet.
It definitely cut down on glare. I just felt like it did not help the screen touch sentivity. I may try it again though, because you are spot on about the glare reduction.The matte screen protector cuts down on glare,so I leave it on.
No problems at all with it on.
Once in a while I have to tap the screen a little harder to get results,my biggest fear is if I takeIt definitely cut down on glare. I just felt like it did not help the screen touch sentivity. I may try it again though, because you are spot on about the glare reduction.
Agreed. It is a one time application.Once in a while I have to tap the screen a little harder to get results,my biggest fear is if I take
it off and decide to put it back on later,could I get it on without creating air bubbles which I
probably could do without.
Love my Tripltec 9Pro as it does far more than run DJI apps and screen never dims in use, the battery is amazing too
Support from Tripltec is amazing.
Based Bridgend, South Wales
