Jacked up Meta Data
VintageSlots
Took the Zoom out for more testing. Looked at the Meta Data in the still photos.
It says I am flying 387 million feet above sea level.
Gotta love DJI testing. Wonder what other Meta Data is jacked up. I do a lot of work for insurance companies and they require accurate Meta Data.
Obviously, it's not correct.
I've seen someone else make the same comment but when checking using a different program, the data was correct.
If you check the exif info in Photoshop, what does it show?
ps the altitude data in exif info comes from GPS and can be very inaccurate (+/- 200 ft is common)
Well, it is not my job to debug DJI SW for them but what the heck. I wrote a PHP script to pull the meta data.
Here it is and as you can see, the altitude data is jacked up. I renamed the file to test.jpg. The altitude data is 1181283169 which is what the data above says (in meters).
FILE.FileName: test.jpg
FILE.FileDateTime: 1536616395
FILE.FileSize: 3846375
FILE.FileType: 2
FILE.MimeType: image/jpeg
FILE.SectionsFound: ANY_TAG, IFD0, THUMBNAIL, EXIF, GPS, INTEROP, WINXP
COMPUTED.html: width="4000" height="2250"
COMPUTED.Height: 2250
COMPUTED.Width: 4000
COMPUTED.IsColor: 1
COMPUTED.ByteOrderMotorola: 0
COMPUTED.ApertureFNumber: f/3.4
COMPUTED.Thumbnail.FileType: 2
COMPUTED.Thumbnail.MimeType: image/jpeg
COMPUTED.Thumbnail.Height: 96
COMPUTED.Thumbnail.Width: 160
IFD0.ImageWidth: 4000
IFD0.ImageLength: 2250
IFD0.BitsPerSample: Array
IFD0.ImageDescription: default
IFD0.Make: DJI
IFD0.Model: FC2204
IFD0.Orientation: 1
IFD0.SamplesPerPixel: 3
IFD0.XResolution: 72/1
IFD0.YResolution: 72/1
IFD0.ResolutionUnit: 2
IFD0.Software: 10.00.06.35
IFD0.DateTime: 2018:09:09 12:01:03
IFD0.YCbCrPositioning: 1
IFD0.Exif_IFD_Pointer: 332
IFD0.GPS_IFD_Pointer: 734
IFD0.Comments: 0.9.142
IFD0.Keywords: N
THUMBNAIL.ImageWidth: 160
THUMBNAIL.ImageLength: 96
THUMBNAIL.Compression: 7
THUMBNAIL.XResolution: 72/1
THUMBNAIL.YResolution: 72/1
THUMBNAIL.ResolutionUnit: 2
THUMBNAIL.JPEGInterchangeFormat: 21078
THUMBNAIL.JPEGInterchangeFormatLength: 18761
EXIF.ExposureTime: 1/1250
EXIF.FNumber: 340/100
EXIF.ExposureProgram: 2
EXIF.ISOSpeedRatings: 100
EXIF.ExifVersion: 0230
EXIF.DateTimeOriginal: 2018:09:09 12:01:03
EXIF.DateTimeDigitized: 2018:09:09 12:01:03
EXIF.ComponentsConfiguration:
EXIF.ExposureBiasValue: 0/10
EXIF.MaxApertureValue: 2971/1000
EXIF.MeteringMode: 2
EXIF.LightSource: 1
EXIF.Flash: 0
EXIF.FocalLength: 6480/1000
EXIF.MakerNote: [ae_dbg_info:
EXIF.FlashPixVersion: 0100
EXIF.ColorSpace: 1
EXIF.ExifImageWidth: 4000
EXIF.ExifImageLength: 2250
EXIF.InteroperabilityOffset: 824
EXIF.FileSource:
EXIF.SceneType:
EXIF.ExposureMode: 0
EXIF.WhiteBalance: 0
EXIF.DigitalZoomRatio: 1/1
EXIF.FocalLengthIn35mmFilm: 38
EXIF.SceneCaptureType: 0
EXIF.GainControl: 0
EXIF.Contrast: 0
EXIF.Saturation: 0
EXIF.Sharpness: 0
EXIF.DeviceSettingDescription:
EXIF.UndefinedTag:0xA432: Array
GPS.GPSVersion:
GPS.GPSLatitudeRef: N
GPS.GPSLatitude: Array
GPS.GPSLongitudeRef: W
GPS.GPSLongitude: Array
GPS.GPSAltitudeRef:
GPS.GPSAltitude: 1181283169/10
INTEROP.InterOperabilityIndex: R98
INTEROP.InterOperabilityVersion: 0100
WINXP.Comments: 0.9.142
WINXP.Keywords: N
Same issue with Pro; also Video files no longer contain ANY GPS info - something that was very useful to me!
Yeah, I discovered that as well today. One of the things I do is line inspections for small rural electric companies. The GPS in the .SRT data is a must.
Won't be able to use the Mavic 2 until they put this back in.
Very annoyed this was yet another feature they removed.
I knew they removed it from mp4, they removed it from SRT as well? Errr! Let DJI know - hope it gets some traction. Should be an easy firmware fix. BUG: Missing GPS Info / Data from Video File Properties
Maybe you have to subtract the distance through the earth between here and DJI's factory? :D
Dimension Drone AZ
