Just joined
England
Good Evening,
I am getting my first drone on Wednesday. I have never owned one before. I am a wildlife & nature photography I wanted to get a done to add video to my content.
Hoping i can learn from you all.
Greetings from Birmingham Alabama!
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
Thank you for the image. Really appreciate it.
Welcome to the forum from south east North Carolina. We have a bunch of smart people here to answer any questions. Take your time learning the drone inside and out. Get yourself setup with a good preflight routine hope you enjoy your new drone.
Fly safe
Blue skies
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members who are willing to help you with any questions you might have. Search the forums using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response.
Fly safe, enjoy and stay safe!
utahloanrelief
