If you can get your hands on one of these…you’re good. I purchased one for my MP3 ProI often have to use Mavic 3 on short notice and don't have chance to keep them at 50% charge. If I keep them fully charged
at all times does this severely kill longevity? What do you do when you need to keep batteries topped up for quick deployment?
Yep... that's how it is.Reading material. Check the number 5 paragraph.
Tips to Keep Your DJI Drone Batteries Healthy and Safe
How should you store your Intelligent Flight batteries? Can you use a third-party charger? Learn about drone battery charging, storage, and maintenance.enterprise-insights.dji.com
NO!!I am a new drone pilot and have zero knowledge about the batteries.. If I may use this same thread for a question? Should you run batteries completely down before recharge ?
Pure technically, running DJI batteries the whole way down to 0% will not harm them in a disastrous way... LiPo batteries have a safe voltage span (with some safety margin in the lower end) where they can be used without destroying them, it's between 4,2-3,5V/cell. A DJI LiPo is at 3,5V/cell at indicated 0%.I am a new drone pilot and have zero knowledge about the batteries.. If I may use this same thread for a question? Should you run batteries completely down before recharge ?
I didn't know about #8. It says charging and discharging the battery is critical to accurate battery percentages.Reading material. Check the number 5 paragraph.
Some claim it’s a good idea to run them down close to zero on occasion but not every time they are used.Should you run batteries completely down before recharge ?
NoI am a new drone pilot and have zero knowledge about the batteries.. If I may use this same thread for a question? Should you run batteries completely down before recharge ?
Page 38 of the Mavic 3 User Manual states that the battery will discharge to 96% after 3 days and then down to 60% after 9 days.I often have to use Mavic 3 on short notice and don't have chance to keep them at 50% charge. If I keep them fully charged
Yes, that is what DJI told me. The important step is to not store the battery when you have discharged it to close to zero. That can brick the battery. It must be charged up to 50-60% soon after discharging.Some claim it’s a good idea to run them down close to zero on occasion but not every time they are used.
Thanks for sending that reference. I hope that with a future update DJI let’s us change the days to discharge to something less than 10 days. With the capacity of the M3 batteries if I don’t pay attention to rotating the usage I could easily go longer than 3 months without cycling my batteries. Also, I never discharge as low as 20% which seems to be necessary on that interval to maximize life.Reading material. Check the number 5 paragraph.
NO,but 12 to 20 % is healthy.I am a new drone pilot and have zero knowledge about the batteries.. If I may use this same thread for a question? Should you run batteries completely down before recharge ?
The number of charge cycles are visible in the app. I use a small sticker on the battery to track that number. Most office supply stores have them.M3 batteries if I don’t pay attention to rotating the usage
50% counts as a half cycle towards lifetime cycles. Not sure how DJI counts them in the app. I've kept most of my batteries 100% charged all the time, and never worry about it. Worst that can happen is swelling, which was an issue with Mavic 2 batteries, but not until they were at least a year old! Just follow the advice I gave you above, and you'll be fine. Just rotate the battery you keep charged at 100%.So does the auto discharge to 50% count as 1/2 a cycle? I think lithium batteries have a 500 charge/discharge life? Also, anyone keep them 100% charged all the time and did this severely shorten lifespan in your experience? Or did you have newish battery suddenly die due to keeping battery charged at all times for 1-2 months? When I am on an out-of-town job I usually am out for 2-3 weeks and need to have drone ready for deployment on short notice so need to keep at least one battery topped up. Will follow the advice here and keep one topped up and others at 50% then charge them if necessary.
