kml in google earth pro
Jiker69
Gabbs, Nevada
I need a little help with a KML files. Once upon a time I imported the KML into Google Earth Pro (I think) and I could fill in the distance from the drone flight to the ground with a color of my choosing (hope I didn't confuse people). I made visualizing the height easier than just looking at an elevated line. Has anyone does this with Google Earth Pro or is it with a different program? I also could see how I was moving the sticks.
Thank You
Reactions: Dragonpainter
Huh ?
you said " I also could see how I was moving the sticks. "
...in Google Earth PRO ?
How are your rc sticks linked to G Earth Pro?
As far as Elevation goes... you need to set the EXTRUDE Variable in your KLM -
for the Path
Huh ?
for the Path
Huh?
Response lacked instructions and creativity.
Assume stick controls means rudder, but could be any other parameter (throttle, heading, battery voltage, pitch etc.).
Download your FlightRecord. It is a CSV file.
Set Google Earth Tools>Option to Decimal Degree and Units to Feet (or whatever the parameters in FlightRecord.
Open in Google Earth File>Open. Set Type to CSV and select your flight record.
File is Delimited, Comma.
Use OSD Longitude and Latitude to set location. Finish.
Create a Style Template.
Set Name as RC Rudder.
Set Color from Field as RC Rudder. Example shows palette colors as Red to orange to yellow with 3 buckets. In my file, 1024 was zero, so I set it as the mid value and orange. These settings can be adjusted to your preference.
Set Height from Field: OSD_Height_Feet. Continuous and Feet.
Red means right stick, yellow is left and orange is neutral. Values are amount of rudder relative to 1024. Could spend more time revising, but most of that is personal preference.
Google Earth is powerful, and stay creative.
Reactions: REPR762 and Rchawks
sscott062
