Latest Firmware update on MP2
SnowSkier
Hi all,
Referring to Mavic Pro 2, when I start the APP I got a red message saying:
"Aircratf firmware has been updated to late version 01.00.0200"
Does this mean I got the latest firmware?
Best thing to do is check what firmware version you are running via the Go4 app. If it’s showing the latest version then your good to go;)
Just go into “general settings”
Then press “about”
That will tell you what firmware you’re running
I’ve always had to force mine to update via the Go4 app
It might be worth trying to force the firmware update
Do you have more than one battery? If so, the other batteries will need updates. Usually the app will say "inconsistent firmware" when that's the case.
RC needs update too.
Use assistant 2 to manage AC firmware.
Reactions: IronReel
Assistant 2 is another problem I have...
Tried last night and it didn't work. I'm not able to stablish contact between AC and PC. Read somewhere I have to disable drivers signatures...
Livermore
