Leg Extensions
Diesel9a1
Kent, UK
I have a set of MyArmor Leg Extensions for the Mavic. The rear and front right, fit perfectly. The front left (from the Mavic point of view) does not fit. As I push the extension on, you can see it has dented the leg of the Mavic.
I emailed MyArmor and they apologised and sent a replacement set. I have just tried them out and the exact same thing!
Now the question is, is the leg of the Mavic a different size compared to the right leg?
Using some digital calipers:
Front left leg is 12.1mm x 9.3mm
Front right leg is 12.66mm x 9.74mm
There have been other, similar, reports here about the two front legs being different sizes. Sorry I don't have a link to those conversations - but I believe that you are not alone in discovering this issue.
SURV69
