While following me did not see the branch - was about to stabilize itself in the air but hit the lamp post and landed on the ground without a scratch even on props!!!
Thank You!Ouch! Glad there were no scratches. Any ill effects at all?
The obstacle avoidance needs code added to avoid a loose mesh also. That is basically what bare twigs in a cluster resemble.
BTW love your videos!
Glad it's fine Alex, but I'm not sure what you expected it to do with all those scattered tree branches. False readings between the gaps to continue to go, stop or what? It never hit the lamp post as far as I can tell.While following me did not see the branch - was about to stabilize itself in the air but hit the lamp post and landed on the ground without a scratch even on props!!!
