LG 4 phone DJI 4 app crashes upon start up.
tonic316
So I got a mavic pro and when I hook it up to the controller and start the app, the app immediately crashes. I am using an LG 4 on the latest OS. Any ideas?
Thanks for posting this for me. Hopefully someone will be able to answer my problem.
did you try uninstalling GO then using a file manager to delete all the DJI directories, rebooting, then reinstalling?
Sent from my Nexus 6P using Tapatalk
Okay I uninstalled everything dealing with DJI on the cell phone and also all files. Reloaded the DJI 4 still getting "Unfortunately UI has stopped" I even put a USB chord in the centers spot nothing working there.
Sent from my LG-H810 using MavicPilots mobile app
I had the same problem with iPhone 6, I found when I switch the wifi off on iPhone the app works fine most of the the time!!
You should have data on to help with the location, I only had wifi off and although it's much better but the fault (disconnect & reconnect) is sometimes there.
Well I never could get the LG for cell phone to work. But what I did get to work is my LG 8 tablet. What I need to know now is do you have to use the DJI 4 app specifically for the Mavic Pro to fly properly. I have a P3P which uses the DJI go and on that app it has the Mavic Pro to use and I was able to bring it up on the LG 8 tablet. If I have to use the DJI 4 app can you have 2 apps on the same device because I need the DJI app for my P3P to fly.
flydeep
